Another Newbie
bigbass160
just checking out the board. i have a 06 chevy 1500 crew.
mods
k&n drop in filter
40 series flowmaster
ever changing audio setup currently 1 atomic apx 12, 1 digital design m3 amp, 2 kinetik 16v batteries, 1 kenwood 4 ch 600 watt amp, replaced factory speakers with jvc 6 1/2's, 4 1" tweeters, and a ever changing head units.
18" kmc wheels
