Seafoam-ed My Dmax
I have been searching the local autoparts stores here for Seafoam. Low and behold it's always the last place you look. Auto Zone sells it. I had run my tank clear empty and was planning on dumping some kind of fuel treatment in anyway. I bought 2 bottles, one for the tank, and one for the intake/crankcase.
About 2 months ago, my LBZ developed a serious fuel knock when cold. I took it in under warranty and everything checked out. The mechanic said that the LBZ injectors are under the fuel rail and it only takes one instance of some water or bad fuel to make 1 start to to chatter. Also, ULSD has no lubricating properties what so ever and the LBZ, LLY, and LB7 injectors hate it. Long story short, rather than tear the top end apart chasing the noisy injector he gave me some Stanadyne fuel treatment. It seemed to quiet it down but, it took a double dose, and that stuff is not cheap.
I decided to try Seafoam, because everyone on this forum claims it to be liquid gold. I don't think it will eliminate my fuel knock but if there is any water setting on the return side it should push it through. Funny, is that, of course, diesels produce no vacuum so you have to dump it directly into the intake manifold. I just removed the harmonic balancer and it gave me direct feed into the intake manifold. Many people say on gassers that it immediately kills the motor. The DMax acts like a little kid who just got a shot of kool aid. It just reved up for a second or so and then returned to idle speed. I dumped the other 2/3 of the bottle in the crankcase as instructed. After 5 minutes of shut-down, I fired it back up and not an ounce of blue smoke exited the exhaust.
After I run this tank, I will post any mileage/noise results.
Where did you get the idea that ULSD has no lubricating property?
Mark.
Sulfur is a natural fuel lubricant. I work in the fossil fuel industry and I know this for a fact. Here is just one example of an explanation. Google it, you'll find thousands. Idea?
http://en.wikipedia.org/wiki/Lubricant
If you read current information that details the various fuels, older high-sulfer, low-sulfer(500ppm) and ulsd (15ppm) you'll find other additives that aid lubrcation in place of sulfer. To my knowledge GM has always said the D-max never needs fuel additives. I also can't see how a product that says it can be used that many ways, can be good at any of them.
Mark.
WD40? :lol:
KY Jelly :flag:
WD40? :lol:
KY Jelly :flag:
INDEED!!!!
I used a can in the tank, but I was a little hesitant to do any thing else with it. Not sure if it made a difference or not. I'm sure it cleaned some crap out.
Mark.
Mark,
You asked me the question, "where did you get the idea that sulfur is a lubricant?". I answered that for you. GM is basing no fuel additives on good conditioned, water and detergent free, diesel. Here in Colorado, heavy amounts of detergents are added in winter time to work as an anti-gel and stabilizer. The problem is that the BTU value of the fuel suffers. Your right, GM does not recommend a fuel additive, they only recommend their service schedule, which is outlandish and a waste of money. A GM duramax mechanic recommended Standayne to me and I did see results. I would be willing to take a professional's word if he saw repeatable results. Don't rob the thread with your opinions, Seafoam has worked for many on here; do a search.
To you others that actually are interested in wether it worked or not, I will have to run the tank empty and let you know!
I would assume that GM would take into account that there may need to be additives the owners have to put into the fuel tank of their Diesels to prevent fuel gel in very cold temps... Seafoam is a great product to use for that.
The reason for this is because, unlike a gas engine, the air intake is wide open and not throttled on a diesel. You control engine rpm in a diesel by controlling the amount of fuel just like you did by pouring in the seafoam. You added more fuel, there was plenty of combustion air available so the rpm went up until the seafoam was used up.
DEWFPO
DEWFPO
DEWFPO,
Thank makes total sense. I drove it to work this morning because I want to burn this tank out of it quickly to get the system fully treated. It sounds like a diesel pretty much burns the SeaFoam away before it has a chance to clean the top end. Oh well, it has the other 2/3's of the bottle in the crank case and I'm due for an oil change.
    ballencd
    ballencd
  • Who's Online   3 Members, 1 Anonymous, 664 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
