Volant Cai Rich Fuel Mixture Problem
I've been following another post on this and decided to post the info here in a new one regarding what I received from the Volant technician.
The tech informed me that if the directions are not followed exactly, the check engine light will come on, and, as in my case, throw a DTC for "Rich Fuel Mixture". I copied the directions he emailed me below, which were not incuded with my CAI kit. The tech said that because I did not disconnect the battery during the installation and because I did not replace the OEM MAF O-ring with the Volant one, I am getting the DTC and the truck is running rich.
I am going to reinstall the CAI according to the instructions and I'll post the results. I hope this works since I really like the look, quality, and sound of the CAI.
Installation instructions for part number 153532009 4.8, 5.3, 6.0, 6.2L HD
Remove the negative battery cable
Remove the factory engine cover by pulling straight up
Loosen the clamp holding the factory duct to the throttle body
Loosen the clamp holding the factory duct to the air box
On the left side valve cover pull off the crank case vent line
Remove the two screws holding the factory MAF in and remove the sensor
Remove the factory o-ring and replace it with the new Volant ring
Remove the factory air duct form the engine compartment
Pull up on the factory air box and remove it from the engine compartment
Remove the factory tray mount by removing the 5 10mm bolts
Place the Volant box into factory position and tighten down using the hardware provided
Attach the 4.00 to 3.5in reducer to the filter box adapter and tighten clamp #64
Place the new volant throttle body grommet
Press the Volant duct into the open end of the sleeve and onto the throttle body and tighten the clamps
Attach the 3/8 x 10.5in breather hose onto the valve cover and volant breather hose stem
Attach the factory MAF sensor into the volant duct and tighten down with the hardware provided
Reinstall the engine cover
Reattach the negative battery cable
Disconnecting the battery will do nothing as the computer constantly learns. I am interested in seeing how a new o-ring compensates for the changed airflow dynamics. Does the stock o-ring look much different from the Volant one?
I didn't think disconnecting the battery did anything (IE-Made a difference) And I'm also wondering about the o-ring.
I will be installing a GMPP CAI system on a customers '09 Sierra soon (in anticipation of the Pittsburgh tune meet in April) And they make no mention of disconnecting the battery,nor do they supply a new o-ring for the MAF sensor.
I didn't disconnect the battery when I installed my GMPP CAI :dunno: No issues with mine and quite frankly the first I've ever read that :D
The GMPP is the only intake that we have encountered that doesn't have to be compensated for, as it is designed around the GM MAF.
I agree with you all. I can't see how the battery would affect anything. It has not thrown the DTC in last week though, so I think it may have "learned" to use the new setup.
As for the O-ring, the Volant one seems thinner, so I am guessing the MAF will sit lower in the tube.
This is what I got from the Volant techs. I will post when I do my "re-installation"!
UPDATE:
Ok, so I did the "re-installation" this afternoon. I did notice that with the new thinner O-ring supplied by Volant, the MAF sits deeper in the tube. It actually "pops" into place, with the bottom of the MAF flange against the top of the flange on the tube.
I did disconnect the battery like the directions said, but I really think they put it in there for the bozo factor, that someone would have the ignition on and short out the MAF, arc across the positive battery terminal, or something like that. I still don't think it does anything for setting up the computer to learn for increased airflow.
I only drove it for about 20 minutes, and so far no DTC. I'll update again soon, but I'll bet I won't get the DTC now because the MAF is sitting where it is supposed to be inside the tube.......keeping my fingers crossed!
If the problem is solved, and the MAF is now reading properly, you should have noticed a significant increase in power immediately.
Thanks! I have one sitting in the garage, waiting for reinstallation. My first attempt failed, as the damn thing didn't fit! After talking to Daniel, it was discovered that the tube was cut incorrectly. I am waiting for my new tube to arrive.
  • 1 month later...
I added one of these to my truck yesterday, and although my tube was cut correctly, and everything seems to fit as designed, I wasn't very impressed by the way the Tube fits onto the throttle body. The gromet just doesn't seem to hold very tightly. In fact, when I first tightened it, I was checking the fit, and actually pulled the tube loose from the throttle boddy by pulling out on the top of the tube. I then replaced it and made sure the clamp was way tighter than those clamps are designed to be, and it now feels a bit more secure, but certainly not as tight as the OEM tube was. Now I now why Jenna says to make sure you check the fit often.
Are all CAI tubes this way? If only GM was producing the GMPP CAI kits for the 2009 :thumbs:
I am happy with the volant overall though. I don't think it helped much with power, if any, but I wasn't expecting much. My Magnaflow cat-back system is supposed to be here tomorrow, and I get the tune by Justin on March 5th, so things are looking up :lol:
    HWN808
    HWN808
  • Who's Online   7 Members, 0 Anonymous, 995 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
