Snowmobile Package
Because of my back surgery this year the Doctor really doesn t want me riding. I have been anyway, but my wifes not happy. I have two sleds and will only sell as a package at this time.
2009 arctic cat Z1, 1100 EFI, 1000 miles, studs extras and
2006 Sabercat, EFI 500, 1100 miles (wifes) studs extras.
Both ready to ride, garage kept, well maintained sleds.
$10,000. If not I ll be forced to keep riding :lol:
