100,000 Mile Pm
I just hit 97,000 miles and I've started collecting parts/supplies for the 100,000 mile PM. My list goes like this so far.
  • oil/filter
  • spark plugs
  • trans filter/gasket/fluid
  • rearend gasket/fluid
  • belts
  • coolant/hoses/thermostat
  • fuel filter
  • shocks
  • air filter
Any thing else I should consider? I think this will keep me busy most of the day (whenever I do it).
  • oil/filter
  • spark plugs
  • belts
  • fuel filter
  • shocks
  • air filter
Flush power steering pump and brake fluid.
Should be good for another 100k. :dunno:
Do plug wires while you are at it. Stock are pretty good. I'm running MSD.
Consider tensioners while you are doing belts as preventative maintenance. I also pull the pulles and clean and grease the bearings.
Make sure to check on your front suspension/steering parts for wear, as well as the U-joints. If there's anything that appears to be off, replace it and get an alignment.
I was just at a Delpi Ignition class and they tested platinum and iridium spark plugs. At 100,000 miles they found that platinum was worn on average .01 over orginal gap. At 150,000 miles Iridium was only worn .005 over. If you have iridium you could wait but I'll prolly change mine at 100,000 anyway. Definately wires though, Ive seen cars with 80,000 miles and the wires are already worn and loosing the spark out of the insulation. If you do replace them, I would suggest Delco Iridium plugs, they cost more but iridium is far better than platinum, the melting point is quite higher with iridium which equals longer life. Whatever you do don't use Bosch, for some reason GM cars eat them up in no time. Not sure why but see a lot of them fail early.
Some conventional 80-90 for the front diff, auto-trac compatible fluid for the T case.
I liked the Monroe Reflexes for shocks.
Thanks for all of the suggestions. P/S and brake fluid flushes sound good. BTW, all of the stuff on my list I did at 50,000 miles. Probably overkill but I don't like to let anything go 100,000 miles. I will also do the plug wires too. Sounds like a good idea to look at an O2 sensor as well. Thanks again everybody.
which parts store has the best price gaskets for the rear end and trans? I have 67K on mine and feel I should change these fluids.
Thanks
2004 Z71 SLE Ext 5.3 w/ 4.10
Thanks
Any place that sells Federal Mogul gaskets...thats pretty much all I use for engine rebuilds. They make a good gasket
Barring that....McCords gaskets and Mr Gasket ain't bad either.
Not overkill at all. Just protecting your investment. Cheap insurance compared to the cost to replace your truck :rolleyes:
Thanks
The trans. gasket is reusable if in good condition.
On the rear pumpkin' some get buy with using a quality RTV. I prefer a gasket when applicable, but thats my personal preferance.
when my xtreme hit 100,000 miles i did....
nothing... seriously, sold it at 120,000. 1 set of tires original rear drums, 1 set of front pads. greased the ball joints, change oil and put a belt on it and fuel filters, thats it. i have the receipts.
Thanks
for the rear end, i'm assuming your talking the diff, the dealership used silicon and let it make its own seal
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,186 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
