Question About Console/jump Seat Swap
I just bought a 2006 Silverado and it has the 40/20/40 seats in it right now. I would like to take out the jump seat and replace it with a console. I've read some other posts about doing the swap and it looks rather easy. My question is concerning the HVAC ducts in the console. When i remove the dash trim plate and connect the console, is the connection for the ductwork there or will it be non-functional?
Short Answer: Non Functional
Long Answer: Functional with addtional parts;
I am going to assume that you have the console in hand already with the two air vents that come out of the back. If you have the RPO code CJ2, then you will need the just the lower half of the HVAC but if you have the CJ3, you will have to order the entire "module kit".
"CJ2" (Part#89018300) = $65.00 plus shipping.
"CJ3" (Part#89023357) = $200.00 plus shipping.
this information was given to me by Rich (MS3DALE) when I did my console swap. you will have to check your original glovebox sticker to determine if you have the "CJ2" or the "CJ3" option....
I have CJ3, so it looks like my daughter is not getting any heat/air back there, i don't see it being worth $200.
Thanks for the information.
Actually GM Parts direct lists it for $119, so she may get some heat back there yet. I may not add it right away but i may at a later time.
yep, gmpartsdirect is usually cheaper on the part itself but sometimes their shipping can be on the high end side of it. I got it from gmpartsdirect for 127.01 but the shipping was 60 bucks when it actually shipped :dunno:
I wish to clarify this response concerning the CJ2 or the CJ3 option. I am looking at a console with the duct work in the rear with the rear audio controls. I have the cj3 option.
When you say the complete module I assume you mean lower and upper half for my configuration (CJ3). Does #89023357 include everything needed for the conversion? From looking on GMpartsdirect it looks like that is just half an assembly.
Thanks
Kevin
  • 1 month later...
Thanks
Kevin
according to Rich (MS3DALE), Part number# 89023357 is a kit.
Here was what he told me:
"Hey Mike,
What RPO code HVAC system do you have? CJ2 or CJ3?
I priced the lower case half for "CJ2" (Part#89018300) BUT...If you have "CJ3" you have to buy both halves in a "module kit" (Part#89023357) and it lists for $200.98!
Rich"
Sorry for the delayed response.
  • 1 month later...
  • 2 months later...
I would like to replace my console with a jump seat!
WOUld anyone like to swap???
I would swap you if you are still looking for a jump seat. I have the dark charcoal interior.
I'm looking for a jumpseat to replace my current center seat (I have a work truck and it doesn't fold down). Please let me know if you're interested in selling it.
[email protected]
Thanks
Hey Pete, to clarify for those out there: Are you looking for the Charocoal or Tan jumpseat?
[email protected]
Thanks
Honestly I'd do either. Charcoal preferred but I'd settle for a tan one
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
