Broken Plug
grose67
Depends on how much plug is showing...but no matter what...there's particulate in the cylinder...little pieces of insulator and electrode that broke off.
Sorry dude...99% chance he will have to take the head off....unless he has a proverbial horse shoe in his ass.
you said proverbial ahhh lol almost peed myself Aiden,are you here all week? hows the veal??
no wait ,I did pee myself abit
I snapped a plug off in a Mazda Protege, just the porcelain came out of the hole, left the threads behind. I took it to the dealer and fully expected (and was told) the head would have to be removed. The mechanic got it out in 15 minutes with an easy out. The job cost me 20$. It was a 4 cylinder so access was easy, and warming the engine up probably helped since I drove the car to the dealer.
Yup....sometimes you get lucky...I have grabbed them with needle nose vicegrips and gotten them out...but its few and far between.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
