FrankZ Posted January 26, 2010 Posted January 26, 2010 I'm in the process of installing a 5.3L from an 03 Tahoe into my 97 Jeep Cherokee. i got the complete harness along with the engine and tranny. the fuel pump I purchased was supposed to have come from an 03 as well, but as you can see from the pic below the square-ish 4-pin connector on the pump and the connector on my harness is not. Anyone familiar with the GM pumps and able to tell me what connector I need?
jblakeney Posted January 27, 2010 Posted January 27, 2010 I'm in the process of installing a 5.3L from an 03 Tahoe into my 97 Jeep Cherokee. i got the complete harness along with the engine and tranny. the fuel pump I purchased was supposed to have come from an 03 as well, but as you can see from the pic below the square-ish 4-pin connector on the pump and the connector on my harness is not. Anyone familiar with the GM pumps and able to tell me what connector I need? NOT THE ONE YOU HAVE.... haha This is quite crude. But You can look here OR get us some info off the top of the pump and let us come up with the harness numbers.... I did a swap like that in 05... A 75 F100 and a 2004 F150 w/5.4 (rolled over in a wreck less than 10k on the clock)....... Kept the 75 frame change the entire suspension over from the 04 and complete drive train swap. Even had time to get the ABS up and running. Sold it a year or so after I finished to a local Ford dealer..... He drives it to work... He asked about buying it, I said, a outlandish price I figured he would say no to.... His response "So who do I make the check out to?" I came out smelling like a rose... But I would love to have it back now. Jbo
FrankZ Posted January 27, 2010 Author Posted January 27, 2010 There aren't any numbers on the pump at all. I did stumble on this earlier today... http://www.acdelcotechconnect.com/pdf/tsb/tsb_05D-83.pdf After a little more searching i found a bunch of vendors online selling the connector I need. Actually found one (NIB) for $20 and no freight on EBay. Hope this info can help someone in the future.
