Heated O2 Sensors Help
I need to buy (2) sensors
bank 1 sensor 1
bank 2 sensor 1
at acdelco.com , I see the option to buy (pos3) and (pos2)
so i am confused..
could anybody teach me how these are named...
tks.
Sensor 1's are the closest to the engine, sensor 2's are the back ones. Bank 1 is driverside (if I remember correctly) bank 2 is the passanger side.
Going by acdelco.com (from what you posted) you would need pos1 and pos2, 3 and 4 would be the back sensors. The first 2 should be the same part number, the back 2 should be the same part number, but not the same as the fronts. I think the back 2 have longer wires.
I hope this helps, I am not 100% on this info, as its been about 2 years since I replaced a O2 sensor on a GM truck.
