How Do I Take Apart Light Housings?
How do I take apart the headlight and DRL housings on an 03 Silverado to clean them? The front lense is foggy especiall on the DRLs.
Oven.
Oven.
You mean you bake them? :)
Oven.
yep, heat them up to the point where the OEM glue melts...
That's what I did with mine to. Bake them with the oven around 250 degrees. just get them warm enough for the glue to start to melt and pull them apart. I then reheated mine(being real careful not to get cleaning solvent on the old glue) and stuck them back together. Worked for at least 6 months. Then I bit the bullet and bought the H.I.D. lights from Xsighting Lighting. Expensive but D.O.T. legal.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
