Colorado Battery Drain
n9cv
It looks like I put this in the wrong forum I'm sorry I put it in the newbie forum. I think it belongs here instead.
2005 Colorado Z71 WT with I-5. - Manufacture date 9/7/2004
This truck has a 220 ma. battery drain that discharges the battery down to dead over a week or so. I have traced the drain to fuse 37 which is the front 4 way flasher and turn signal bulbs. The bulb circuit goes through the BCM. Removing both bulbs does not change the drain. The drain appears to be in the BCM itself. Removing and reinserting F33 which resets the BCM removes 200 ma. of the drain leaving 20 ma. which I feel is probably the normal load for the BCM. Opening and closing the door starts the drain again. The drain never goes away. I waited one time for 38 hours with the keys removed from the ignition and still had the 220 ma. drain. This is a work truck and does not have electric windows or electric locks. I know next to nothing about the BCM but I feel this is a BCM software problem.
Are there levels of code for the BCM?
Could this possibly have been fixed in later Colorados and all I need is a BCM code update?
How do you check the current code level or update the code level if necessary?
I checked with a local Chevy dealer are got no where.
Thanks for any input or ideas.
the only drain i ever heard of was a recall on the cd player staying on, when you eject a cd while the trucks off, besides that not i haven't encountered any sort of drain..also idk if you can get the z71 on a wt man
Thanks, No CD in this truck. This truck just has the cheap AM-FM radio.
crazy, i thought all the newer WTs came with cd and all the goodies minus carpet lol
Not this one. If they could leave it off of the truck they did. I'm really surprised it has a steering wheel and engine. I guess GM could not figure out how to get by without them.
