Ebay Windoow Tint Precut Kits
anyone use the precut kits before on ebay? i was thinking about giving them a try on the front 2 windows on my 96 yukon.
15 bucks shipped cant really be beat, price wise, lol.
searched, but didnt find any posts that were relevant.
for the front two windows it is just as easy to remove the window, buy some quality tint at the local auto parts store and cut it yourself. Very easy to do if you remove the window.
I've never tried any non name brand tint, my dad has a buddy who runs a tint/detail shop, and he hooks me up with a good price, I only paid $100 for 15% on the whole back window, 35% on the side windows, and a 5% windshield strip.
But for 15 bucks it might be worth a try, if it's shotty you can get it done right and only be out $15
yea, i had planned on removing the windows to do it. going 20% i think would match the factory back windows.
a shop here in town will do it for 50, but im cheap, so im debating on what to do.
no dont get them.It is crap tint you can buy better tint in walmart and can get a roll for $20.00.
I bought a kit once. When I tried to install it I didn't make past the first window. There was all kinds of grit and crap under the film. I ripped it off and paid a pro to do it. Major PITA.
I'd go 15% on the fronts to match the rears. the stock deep tint on the rears is about 17-18%. but you've got to remember in the front you've got the whole windshield letting in sunlight that makes the front tint appear to be lighter than it really is.
I've got 20% on the fronts and on cloudy days it looks dead on, but when the sun is shinning the fronts look a touch lighter than the rear. Just something to think about, because if I could redo it, I would have gone 15% on the front.
I tinted three trucks with the precut ebay tint kits. And all turned out great. My 07 front 2 windows have it and my back rear window has it on it. I only bought them from a guy here in WI with the ebay name of porchguy (I think).
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
