89GMC27
Im from massachusetts just south of boston................the truck isnt in condition for pics right now.........been off the road for about four years, recently replaced the whole front clip so its multicolored right now, not much to look at.................ill get pics up when i get it back up and goin and painted
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
