Brake Troubles?
84 Cookie Monseter
Your gonna have to get the back wheels and drums off. Most likely have to beat them off. Be prepared to replace the shoes when you do. Once you get access you can work on whats locked.
I run into this alot where I live ... Sometimes you can get lucky by grabbing each cable right by each wheel & working it back and forth several times. Then try the same with the main cable just to make sure.
