Passenger Side Windows Stopped Working
4RunnerGuy
I have a 2004 2500HD CC. The power windows will not roll down from the master switch or the individual door switches. Any ideas on what may cause this?
Thank you.
Possibly the window regulator, but I'm not sure, that's just what I've heard of people having trouble with
I've seen people talk about that while I was searching the 'net. The fact that BOTH the windows on the passenger side do not work makes me think its electrical (main switch, circuit breaker, wiring).
is it making any noise like it's trying to go up or down?
No there's no noise. When I try to roll down the passenger rear from the main switch I can here a momentary click coming from that door.
The first place I would look after the fuse box would be the window switch module. Sometimes, you can pull off part of the connector, and switch sides (for testing purposes). If it works, then you know you need a new switch.
