Lowering Your GMT900 (static)
:thumbs:
The 3/6 is so sweet perfect amount of rake! I have to put 17" aluminium wheels on for the winter does this create a clearance issue with the tie rods? My options to lower the truck are probably very limited. DoMDrty are those 17 or 18" with the 4/7 kit? You had mentioned 2" spindles "tires will thank you" if I have a clearance problem how about adjustable struts/springs.
Thanks in advance.
Cheers NOAH.
at a 3/6 the rear will sit a tad bit lower in the rear then the front. You will be fine with 17in wheels and drop spindles just make sure you use the half nut on the bottom of the lower ball joint and trim the bolt. Drop spindles will keep your suspension geometry closer to stock than any other drop component for the front.
There has been a lot of complaints about belltech drop coils tearing the boot on the stock struts, and McGaughy drop coils being too weak causing issues with the alignment. If you want more than a 2in drop up front I would suggest 2in drop spindles and belltech adjustable struts. Just remember that if you decide you want to adjust the struts for a 2in drop you will most likely need a camber kit to align your truck correctly (I highly recommend it).
  • Replies 68
Well I finish my lower install.
That flip kit took a long time to install.
Thanks for this post it was helpfull.
Truck sits about a 1/4" highier in the rear with a full tank of gas.
4/5 drop.
Front:
Ground Force drop spindles
Belltech Street Performance lowering coil-over shocks
Rear:
DJM Performance 6" filpkit
Ground Force drop shackles
Belltech Street Performance shocks
4/5 drop.
Front:
Rear:
Lowered crew cab for the win :thumbs:
Eric I had a 2007 exactly the same even colour.
I know chrome door handles will look great on that truck and maybe a chrome body moulding in the door mouldings. You haven't given us a headon picture make sure you make the front bumper and air dams as wide as possible (hide those tires) that wide stance and lowered front will look awesome.
Did you experience any difficulties with 4x4 aspect and has the cab noise decreased due to less air passing under truck?
  • 2 months later...
What exactly do you mean make the bumper and air dam as wide as possible? Is it adjustable or something?
No i have not experienced any problems except for some drive-train vibration from the drive-shaft, i know it's my pinion angle, i just bought a tool to get set the angle right so I'll be fixing that this weekend.
Since then I've installed a new set of wheels. here are some pictures.
4/5 Drop - 295/35R24
The week after I took these pictures I put the stock shackles in to make the drop a 4/6, I think it looks even better now that the rear fender sits just over 1/2 inch higher over the tire then the front. In these photos the rear fender was about 1.5 inches higher then the front even though it looks pretty much level.
  • 3 years later...
Hey guys I'm going to be doing a 2.5" drop In the rear of my truck to level it out. What air bag kit should I go with?
  • 4 years later...
Quick question  i have a 2009 1500 2wd and want to either level it or do lowering kit but have limited money right now so just trying to level the rear to match the front what are my options and what do you guys suggest for rim and tire size to give it a street truck style i was thinking origionaly on 20x9 oem style wheels of new gen silverado but i like the look of 22 or possibly 24 but i dont want meaty tires but dont want rubber bands on the rims so looking for help.
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,401 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
