Allison Problems
Hey all, I have a new problem with my truck and can't seem to figure it out for the life of me. I am really worried about this one.
2001 2500HD 4x4 8.1, Allison, 94k miles. I just finished performing all the maintenance items up to 100k miles except for the transfer case fluid change.
I just started getting this problem:
When the tranny is cold, it shifts just fine. Once is warms up to operating temps, the dash indicator will flash and eventually (in 3-5 minutes) disappear from the D. Then as you continue driving (assuming you slow down and the tranny downshifts), it will not shift out of 3rd gear (ie. you come to a stop light, it will downshift all the way to 1st just fine, then as you accelerate it will not come out of 3rd).
If you come to a complete stop and put it in P, sometimes the indicator will light up in P and other times it will not. Then as you slowly run through the gears, it is hit and miss whether it will engage into R (if it does not engage, it will stay in N) and the same for D. Once you get to 3rd, there's a huge thunk and the truck lurches forward as it engages into 3rd.
Sometimes, the indicator will show solid, other times it will flash. If you continue, the indicator will again disappear as you enter 2nd and reappear in 1st. If you go back up in gears again, you get a hit and miss situation whether it will engage into D.
There is no check engine light and again, all fluids are at spec. This started happening before I changed the trans fluid and filter but the fluid levels had been fine before I changed it (and they had been changed around 50k miles).
One thing that I have not done is replace the sensor on the side of the transmission. When I changed the fluid, it was used (off-pink) but not burnt (brown).
Any ideas would be greatly appreciated.
Course, these trannies are sooo cheap, maybe I should just put a new one in and call it good :shakehead:
Bah, would an admin mind moving this post to the HD forum please? Sorry about that - it's late and I'm stressed about my tranny :shakehead:
Something else I just found (on another forum... shhh):
Could be either the Neutral Saftey Switch or the Reverse Pressure Switch.
I'll give those a shot tomorrow and see if it's either of those. Anyone else have any other suggestions?
The NSBU sensor has been a known problem on the early Allison's. It's not expensive if you replace it yourself and it's fairly easy to replace.
DEWFPO
Thanks DEWFPO. That's two votes for the Neutral Safety Switch. I'll have to see if there's anyone open today that has these. RockAuto's got them for around $120. I guess 120 is better than 4500.
OK, as a follow-up, I replaced the Neutral Safety Switch and drove over 100 miles today (about 50 of those I was pulling an empty flatbed). I didn't have a single issue with the transmission. Keeping my fingers crossed, but it looks like that was the issue.
    HWN808
    HWN808
  • Who's Online   5 Members, 0 Anonymous, 1,006 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
