2009 6.0 Mpg
i've read many posts about gas milage, but am wondering if GM changed something in emissions, or the motor from earlier GMT-900 versions. My 2009 6.0, highway at 70 averages 13.2 dic, and 13.5 dic at 75. Granted I have some hills, and climate set to auto. Still much lower than waht I have seen and I'm not towing or carrying any weight.
I average around 13-14mpg intown and 16-18mpg highway. Mileage drops hard above 65mph.. so if you keep it below there, you'll see the 17-18mpg your window sticker states. :shakehead:
I'm guessing that your drive a 3/4 ton not a 1/2. If your getting that then your doing pretty good considering you moving 3+ tons at that speed 75 MPH.
I would take that and be happy. I've seen a lot of people with the 6.0 getting 10.
Yes its 3/4 ton 4x4. Curb weight is 5950. My F150 was also around same curb weight , slightly bigger, and averaged 15.5 similar gearing 6 speed auto and 3.73 axle.
Add in gas plus you and I was close to weight. The F150 and the 3/4 Chevy are two completely different beasts though with different capabilities. How many miles are on Chevy? Might take a little bit to break in I noticed mine climb about 1 -1.5 over the first 5k as everything worked in.
I know they are different, though towing capacity on the F150 was 11K, compared to to 96K on the silverado. Currently have 1900 miles and changed oil at 1000 miles. Running BP & shell regular unleaded, and premium every other fillup. Tire pressures, 50 front, 70 rear
I'd honestly say your doing pretty good overall. Sounds like your doing everything right. Drive it and enjoy it.
I would drop the rear pressure to 45/50 if your not towing/hauling anything. Won't get you any better mileage but it'll smooth out the ride a little. Bump it back up when you do need to haul/tow.
BTW - I don't think we've ever seen pics of your truck?
:P Talk about a tow beast!
Wondered how long that would take before some jumped on that one.
I mant 9600K. Something wrong with my editor or browser as it wouldn't let me edit.
Why are you switching back and forth with the 87-92 fuel? The computer will never adjust to the higher octane and run like it always has 87-89 in it. It usally takes several back to back 92 octane fill-ups for the computer to "learn" that it has the "better" fuel and then raise the timing a bit(thus giving better power and fuel milage). Or if you get a tune and then the truck computer expects the 92 fuel and thus you get the higher power and milage. Also it is not unknown for these motors to take 3-6K to get "broken-in". I hope this helps.
Ok, I will use regular, as I was experimenting on how much I save with premium for .20 more per gallon.
I'd be curious about going 60 - 65. With the 3.73 gears in my truck, my MPG drops significantly the closer and further above 70 I go. (I can't help it though :P )
But if I'm on state highways at 55 or 60, it's MUCH better! :P
Even 70mph is slow for me. My commute is 100 miles per day, mostly highway, though 6 miles off road getting to and from highway.
:crackup: Then I think for a 3/4 ton Heavy Duty truck going 75mph on the Interstate, 13 or 14 is good! :crackup:
    needafix
    needafix
  • Who's Online   4 Members, 0 Anonymous, 651 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
