07 Vmax Transmission Problems
hey everyone
I recently had a vette servo installed in my 07 max along with a new filter and fluid flush (not power flushed) I picked up a gm filter kit and the correct dexron VI fluid.
I have been only driving around town as of the last 2 weeks and finally took it out on the highway tonight.
the truck shifts great 1st to second, second to third but doesnt shift into 4th and does not lock up the torque converter (I believe the truck has a lock up) the rpms also drop down to idle when coasting (maybe normal) it does not appear to be slipping any either.
when you select the shifter to third the rpms do not drop off and the truck has no hesitation or slipping feeling when going from coasting to giving it a fair amount of throttle.
its a little weird seeing the truck at 3000rpms at 75mph.
when the servo was installed and the fluid and filter were changed there was no burnt smell to the fluid and it was as pink as the new stuff is.
the fluid is still pink and still smells good now, when I noticed the trans was not shifting I kept an eye on the temp and it was at 41c / 104f and not heating up past that point.
should I have the servo removed? could I have done damage to the trans? any ideas at all
only odd thing I have ever noticed is that the truck surges slightly when you are lightly on the brake in drive and just barely creeping forward. As soon as you release the pressure from the break it picks up idle speed and runs very smooth.
thanks
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
