Bilstein Shocks
I have a 2006 Gmc sierra 1500 z71 and ever since i put 2 inch leveling kit on and my 285/70/17 mickey thompsons ive noticed that my ride quality is awful. Therefore i want to get some new shocks and i have been looking at the bilstein 5100 series. I am wondering can i get the HD shocks designed for the 1500 HD will taht work or is there an HD shock designed for the regular 1500 trucks? If anyone has part numbers that would be awesome thanks
the 5100 series is an HD shock designed for lifted vehicles like yours. this is what I am running and I love them.
front w/ 2 inch lift
http://www.shockwarehouse.com/site/product...oad-Racing-Unit
rear (up to 1 inch, but stock works too)
Don't expect the ride quality to get much better... that's part of putting a "leveling kit" on a GMT800 truck. The bad ride quality is from the angles of the control arms (changes load path), the added preload on the torsion bars (more rebound energy), and reduced down travel (OEM ride height allows for 3" of down travel. With a 2" leveling kit you only have 1" left).
If your shocks are worn than you may be bottoming out the suspension more than it should since you only have 1" of down travel left... so the new shocks may help a little bit. But don't expect any miracles.
FWIW I went 1.5-2" on my 2005 1500 when I had it. Figured i could live with the stiffer ride and buy a real suspension lift when i graduated college. I hated the ride so much I put the suspension lift on it about 2 months later.. in the middle of a semester :cheers: I tried a few different shock options too; i was a mechanic so I got stuff at cost. Tried "soft" shocks and stiff shocks... every combination felt like i was driving a dump truck. The roads are horrible around where I live and where i was commuting for school, so that 1" of down travel was just not working out.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
