Craftsman Trolley Jack
EvanWilliams
I was in Sears today. Not loving the scissor jack that came with my Silverado. Hadn't gotten around to doing anything about it until today. Saw a "craftsman trolley jack" (Floor Jack) for 29.99. Regular 49 bucks.
I picked one up. Would have gotten two (one for wife's Honda Ridgeline) except that it is pretty heavy so I might get one of the aluminum "racing" models that is lighter.
Anyone interested check out Sears.
Here is a link to the sale http://www.sears.com/shc/s/p_10153_12605_0...word=floor+jack .
Sometimes they offer a similar deal with two jack stands included.
Does it lift high enough to be useful with your truck?
I have three of them but I didnt think they lifted high enough to pick the truck up much, perhaps using it under the axle.
My wife asked the same thing. I am gonna check. What a bonehead!!!!!! Geez. Can't believe I didn't check.
Well, for that price, you can always get a big block of wood to put under the floor jack. I have a Sears floor jack, albeit a much more expensive one, and it lifted the rear of my 2500 HD (under the axle) just fine. And that was without any extra raising of the jack.
Is it OK to put the jack under the axle?
I went shopping on Black Friday (never again) and scored the 3 ton version of that jack, a creeper, and 2 jackstands for $60. I've used the jack plenty of times on my truck, and it won't reach the frame, but it reaches my skidplate and rear diff even with 35's with no problem. I read online reviews and some said that it wasn't worth it, but I scored it pretty cheap so I figured I'd give it a shot. It seems to be very solid so far. My only complaint is that the jackstands aren't anywhere near reaching my frame, but they work on every other non-lifted vehicle.
I could find out differently here, but, yes, I would say it is. Well, let's put it this way; I did and haven't noticed any ill effects.
I picked one up a few weeks ago. They do work well for the price. They aren't as good as a regular floor jack, but at 1/10th the price, it doesnt matter.
I've seen those (I work in a mall and try to check out Sears a couple times a week) but decided to pass. I've got a Wal-Mart special chrome GM 2 1/4 ton jack but will be getting a more heavy duty one in the near future. The short handle, low weight capacity and lack of lift height on my jack makes it less than ideal for the rare occasions when I need to jack up my truck. A 6x6" block works, and jackstands are always used, but that little jack just scares me whenever I use it.
I've been looking at Harbor Freight as well as Sears and want to get a four ton, but may settle for a 3 ton.
I keep wanting to buy a jack, but can't find the reason to. I have yet to use the one in the truck with the exception of the one time I got a flat. I fit right under to change the oil and that's about the extent of my needs to get under my truck. That is a good deal though.
About the only need I have for a jack is during tire rotations. Eventually, though, I'll need one for brakes and to replace the left front hub assembly.
I have a little 2.5 ton jack with a lift of 21" that works just fine, but when I grow up I'm going to steal my dad's/ He has a 7 ton R.V. jack that has a lift of 39", the only downside to his jack is that it if you want to pick it up it takes 2 guys.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
