Which Channel?
I am looking to add an 8" Kicker Solo Baric L5 into my 2007 GMC Sierra Crew cab center console and power it by a Kicker 08ZX300.1 Amplifier. I understand that I need to use a PAC adapter AEOM-GM1416 so that I can get RCA outs from my stereo to feed the amplifier, but my question is, which channel would I use? As I understand it, the PAC adapter gives you four channels out for each of the speakers, but not one specifically for the sub. Is one better to use than the others? I also understand that the front left is the one that is used for door chimes and things so I wouldn't want to use that one. So would I just pick one of the other three and let the others hang or is there some other adapter I should be using? Thanks in advance.
Its my understanding that you can use either or. I used the rears on my Camaro. Either way, its easy enough to switch if for some reason that doesn't sound good.
