Oil Pressure..
i was just curious as to what is the maximum oil pressure the gen 3 and 4 vortecs can withstand before leakage? i know theres an oil pressure valve that will open if the pressure gets too high, but say the valve diden't work, i mean what are the effects of driving with high oil pressure?
It goes full sweep of the gauge regularly when you go WOT. 60PSI I think that is....not sure.
if pressure gets to high, the weakest seal will blow.
i noticed alot of folks i go to college with just hop in and floor it, and i can imagine the oil pressure is through the roof when its cold out, i'm trying to figure out if its harmful, in my haynes repair guide is mentions too much oil pressure will blow the seals...
yup high pressure will blow seals....usually caused by a blockage somewhere though...the pump will not make enough pressure to blow your seals under normal conditions. Just taking off cold causes a lot worse problems than blown seals man...you should give it 30 seconds before you take off, just to let the oil circulate around the engine. Its not 100% necessary, but it gives me a warm fuzzy.
you said warm fuzzy,EEEEWWWWWWW
I have done the start and go with my 6.2 diesel for about a million yrs and it is fine,do more homework and less automotive engineering Burt,lol
:happysad::fume::lol:
If the 6.2L big dirty has lasted that's a testament....those engines quit if you sneezed on them....modified gas engine...not the best feat of GM engineering.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
