Wiring To Coil Packs
jiminycricket
Hey guys,
My question is this. Where can i find the 12v positive wire that feeds power to each individual coil pak for the spark plugs. Its a 4.8L on a 99 sierra. i know there are 4 different wires going to each pak. Each on has a red and black for positive and ground but the other two im not to sure about. So im assuming that the eight red wires eventually join togehter somewhere and go to a fuse in the underhood fuse pannel. Any help would be greatly appreciated.
Thanks
james
try the dealer or a parts store, i can't imagine they are too rare of wire...why do you need the wires?
I need to put the wire feeding power to the spark plugs. I need it to hook it uo to a momentary switch so when i hit the switch, it cuts power to the engine and puts the power to another source. Dealer will probably charge me way to much for something that is probably simple. I just want to know where this wire branches off to feed the coil paks.
All right you peaked my interest enough to go to the garage for my shop manual. I am not exactly sure what you are looking for but here goes.
On the 4 wire connector that plugs into the coil, looking at the plug with the tub up and from left to right the pins are;
1. 12 volt supply
2. Ignition control from pcm
3. Reference Low
4. Ground
According to wiring diagram all the 12 volt supplies are tied together and the wire should be pink.
So what's the other source you want to run power too.
1. 12 volt supply
3. Reference Low
4. Ground
Thanks for that man. I found the pink wires but there are two. One frome the left side of the motor to that set of plugs and another from the right side plugs. I believe they are there own seperate wire going to the fuse bux under the hood compartment. Fuses IGN A and IGN B. These fuses are listed as ignition switch and the other fuses have other names ontop like ignition switch, fuel injector, etc. I bought a kit that cuts power to the spark plugs so more fuel goes into the exhaust :D for a flamethrower. So i have to run the 12v wire to my switch and the other end to the switch so when i push the button it puts the power to another source. so im unsure if the wires join together around the steering column or before the fuse box then split to become two seperate wires for each bank of the plugs.
Thanks
James
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
