Almost There!
got the 07 CC two weeks ago and am almost done with personalizing it for my taste. i had to get a new windshield cause the factory one was scratched to heck. i got the tonneau cover and windows tinted. on tuesday i have the linex app. and after that i want to get running boards and a nav/dvd head unit. and i will enjoy the truck for the summer. then in the fall i am going to get some snow tires, a wester HTS plow and some timbrens and hopefully make some money to pay most of this truck off if we get enough snow.
happy camper here.
only thing i need to address is that when i turn the wheel all the way to the right in a parking lot the inside of the passenger side tire rubs on the fender liner. i may try to take a heat gun and mold it back a bit or i may just dremel a little off. what do you guys think?
maybe it got bent in somehow but it shouldn't do that stock. if you got it from a gm certified dealer (and you have a warranty) i would take it to them and tell them before hacking it up.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
