Funny Sight From Friday
snyderfarms
So I was on my drive to the womans house when I met a jeep cherokee towing a powerjoke on a trailer juuuuussst long enough that all four tires could fit :cool: .... Needless to say the rear of the jeep was firmly supported by helper springs, or in this case bump stops, and the front looked like it was barely touching the highway. Yes, thats right the highway. This joker was pulling this stunt on a major highway here in Missouri... While seeing this I was thinking of how if I tried that with my half-ton, which is way more qualified for the task than the jeep but still a decent load for my truck, that I would get pulled over for exceeding the weight limit of my license. But here in Missouri if you have car tags you could pull anything you want regardless of weight, assuming you could get hitched of course. Anway thus concludes this story
It's camping season here, we see the same kinda stuff here all the time....a mini van pulling a 30 foot travel trailer, all loaded down, hitch about 2 inches from the ground....and they all have tags from a certain area, don't wanna insult anyone so I'll leave "where from" out
When I lived in GA I had a neighbor who had a Ram 3500 diesel and he would pull his 30ft gooseneck travel trailer, with his 22' sport boat attached to the back of that. LOL it was quite a rig. I always questioned the legality of it but he never got pulled over.
double trailers are legal in most states, I know Florida is an exception. Some states even allow tripple trailers, which is crazy.
I thought that terminology was only for 18 wheeler type trailers...
I saw a crazy on I-90 by LaX, WI with a late 90s early 2000's Pontiac Grand Prix or Am. Hooked to that was a 14 foot or so tandem axle Enclosed U-Haul trailer. The ass end had to be close to scrapeing the ground, and the front was pointed to the sky. It looked as if the car hit any bump it would do a wheelie. What amazed me is, why U-Haul would let the guy tow with that? Don't they look at the tow vehicle BEFORE they let someone take off? I was damn glad he was on that side of the interstate and I was on the other side. He was from MN I believe if I remember right, but regardless, one of those things that makes you shake your head and go what the hell.
I'm guessing Arkansas :thumbs:
WTF? No Pictures?
Na, we met on the highway it was over by the time I coulda picked my phone up
where the hells lax wi at?
LaCrosse Wi. ? I towed a mid 80's Olds 98 2dr on a double axle trailer with my 1979 V6 Monte Carlo. Couldn't go over 35mph for the 20 mile trip. Stupid and funny.
Yep La Crosse, WI. Your situation is different, 79 Monte has a little weight to her. My dad had a 78 Caprice Classic, black 350 with a heavy duty auto, I think the Turbo 350. But anyway, he had a 5x8 utility trailer that he hauled with that car and multiple John Deere garden tractors for mowing. But a late 90's early 2000's Grand Prix or Am is not a very good tow vehicle.
Pry a frame to.... :dunno: .. It's amazing the stupid things people can come up with
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
