Steering Wheel Question
I'm looking to replace the plastic parts next to the airbag/horn. On the work truck, I have a rubber like crap, covering shinny plastic. Over a little time the rubber has worn off, and I'm looking to upgrade/replace. Also how hard would it be to remove the old an install the new?
Wheel_Pic.tiff
Wheel_Pic.tiff
Wheel_Pic.tiff
Wheel_Pic.tiff
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
