Leveling Kit Reviews
what do you have and how is it doing? fill in the blanks
what kit do you have?________
how long have you had it?_______
has it affected ride quality?______
price?____
other comments______
Rough Country
1.5 Months
Not really on my stock wheels - put my 26's on a week after and I felt a slight difference
Think it was $90cnd
Looks good, and well worth it.
Rough Country 2inch
5 months
Not at all. Kept it stock. Rims and tires will affect quality but I don't believe rough country did. Pretty much still feels stock to me.
$65
Great design, durable product, does what it's supposed to
Rough Country 2inch
5 months
$65
+1 Exactly what Brett said. Even the timing is just about the same! :thumbs: Getting ready to upgrade wheels and tires though!!
Rough Country 2"
close to a year
Nope, if there is a difference it is minimal especially in stock form
$65or $75 I can't remember
Gives the truck a great looking stance and also looks good when removing the stock valance
Truxxx 2.5/1 Lift Level
about 46k miles - 1 1/2 years
I think the D rated A/Ts had more to do with the stiffer ride
$250 I think
Looks the way GM should have brought them off the line.
Bilstein Leveling Shocks
3-4 Months
The truck has a slightly stiffer ride but definitely an improvement over stock. IMO
Around $200
Gives the truck a great look but I also removed the valance.
what kit do you have?_____RC___
how long have you had it?___About one year____
has it affected ride quality?___no___
price?__70__
other comments___Makes truck look much better___
what kit do you have?________ Rough Country
how long have you had it?_______ 8 Months
has it affected ride quality?______ Yes
price?____ $70
other comments:
Bell Tech Drop Shackles 2"
1.5 Months
Yes, the suspension is more stiff. It handles turns better but I dont like the stiffer ride.
$54
It lowered the rear 2 inches but it is still 1/2" higher in the rear. It's not completely level but it looks better with a 1/2" rake. The kit comes with bushings for the u-bolts so you can remove the stock block and lower it an additional 1".
Rough Country 2"
1 year and 10,000 miles
Ride quality is exactly the same as before the level.
$79.95
Truck looks great with it! No problems whatsoever.
what kit do you have? Fabtech
how long have you had it? 3 years
has it affected ride quality? Nope
price? $300 installed (that's actually a good price around here)
other comments make sure you get a full front end allignment after level!
what kit do you have?________Bilstein 5100 series shocks on highest setting
how long have you had it?_______8 Months
has it affected ride quality?______In a positive way, yes.
price?____I got the front two for $220 installed
other comments______I am not sure why you would do anything else.
Top = Ready Lift Spacer - 1"
Bottom = Rough Country - 2"
I have a Warn Transformer Grill Guard with Reciever Block / Light Hoops & 2nd Battery
10K Miles
not noticable - its a truck !!!
no issues with Upper Ball Joints as of yet ,,,
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
