Help Wiring Fluorescent Light To Plug....
terrible1one3
Here is the deal, I built a work stand, bought a fluorescent light for it.
It is a light that is meant to be hard wired in, I want to run it through a switch and into an outlet via a standard 3 prong plug.
What I bought is 12G wire (probably too big but does it matter?) I am running black and white out of the light, black into the top of the on/off switch, and also the black from the plug is wired to that, the white from the light and the white from the plug are wired to the bottom post of the switch. Then finally the ground is wired to the switch from the plug.
When I plug in the light, it turns on and works. When I flick the switch it blows the fuse.
Can someone explain in dummy terms how to wire this correctly?
Thanks!
-Mike
Thanks!
-Mike
First off, I am no electrician, but I have stayed at a Holiday Inn Express before. This diagram should show you what you need to know.
Thanks!
-Mike
That did it! The white wired directly to the white and the black going through the switch made everything work. I don't quite understand it but I appreciate it! Thanks a bunch!
Plus that holiday inn joke had me laughing pretty good :thumbs:
When you flipped the switch to the "on" position you created a dead short between the black and white wires. That's why it blew the fuse. With the switch in the "off" positon the wireing basically bypassed the switch like it wasn't even there and that's why the light came on when you plugged it in.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
