Help
gmcgirl
Yes they should fit but I HIGHLY recommand you not to buy them. The tires are too small and the wheels look well used.
I would run the stock wheels until you find something better.
Thanks, I was thinking the same just wanted another opinion!
That and it doesn't say what GM 6 bolt pattern it came off of. Could be a Trailblazer...totally different pattern.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 254 Guests (See full list)
