-Wardster
You reminded me. I can't use the line "the house payment sits in the garage anymore" as I paid Blue off in January and managed to save up some cash to get a place built.
I actually own the apartment building I live in, so the truck is the only payment I have to make. I could actually buy a pretty big house for the same money, but I am content with where I am. :)
Funny i saw this thread on the eve of leaving to go on vacation at our 2nd home in Madison Ohio. hahaha
Right on the lake baby! :chevy:
Right on the lake baby! :D
How long will you be in Madison for? Unfortunately or fortunately depending on your view, I'm in Vegas until the 1st of Sept. or else we could've perhaps arranged a little OH/PA gathering.
  • 9 months later...
Stay away from TOTH in Akron????? What a joke they Are. I'll stop there becausem
my kids are in the room.
Edited by Rookie
I love quaker city. i used to go there most week end befor i converted to trucks. Norwalk still is the track all tracks should be designed after. Used to own a 77 monte carlo 10.52 @ 122 MPH in the quater mile. o yea i almost for got all motor!!!!!!!!
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 423 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
