Front Door Windows Is Slow Going Up
When i roll up the front window when they get about half way up they get slower. So is the motor going out on them or what
try putting dielectric grease in the window tracks, NOT across the bottom felt, just the sides. i use a QTip when i do mine. if that doesn't help pull your panels and lube your tracks..
good luck
Get a new regulator and motor. The cable that pulls the window up is probably starting to break..
Jbo
