Rim And Tire Fitment
I have a 2007 Silverado extended cab 4x4 and I cannot find information on what is the maximum tire size that will fit on this truck without any cutting. I am having a dealer install the ReadyLift 2.25 leveling kit with the 3" rear block kit as well. I want to keep my stock 18" rims and have chosen a 33" inch tire. I am looking at 295/65/18 or 275/70/18 however, I dont want a tire that looks too skinny. Any advice? I see some posts of people running 33x12.5x18 but I am thinking those tires might be too wide for an 8" wide rim and may require cutting. 295/65/18 is not a common size so need some assistance? Thanks.
I have the 275/70/18's on my stock rims and I have no rub issues. I have heard of people running the 285/65/18's without issue but I haven't heard of anyone running the 295 so I can't help with that size. I have the skyjacker 2" lift. 03181-1.jpg
Brad,
Those tires look nice on your truck. Are they narrow?
They are by no means WIDE but they aren't real narrow. They don't look like little skinny tires on the truck but they don't stick out either. I can try to take a better picture that shows there width sometime tomorrow when I get a minute.
Brad,
frontlock.jpgClose up shot
03183.jpg Kinda dark but a little better shot
Those are the only ones I have on the computer right now. But I will try taking some better ones tomorrow at better angles to try and show the width better.
Man those tires look great on your truck. This is exactly what I am thinking of doing when I need to replace my tires. How much were those tires if you don't mind me asking? Also, you just have a 2" front leveling kit, correct? Any lift to the rear?
I have a 2.5" front leveling kit, stock rear height and my truck looks a lot higher than yours does. Did you have to get an alignment when you went to the bigger tires? Also do you know if your speedometer is off now?
NWI, take a look at the suspension mod section. On the first page I have a post for the Zone 3.5 combo installed and there is a picture of the front of my truck with the 275/70/18 tires installed. I don't believe that they look too narrow by any means. Good luck!
I paid like $937.00 for all 4. The guy didn't charge me for mounting/balancing.
A I have is a Skyjacker 2" Level. No rear lift. I didn't get an alignment after the tires; just the level.
Didn't check my speedo with a GPS so I don't know if it was off. I have a Diablo Tuner now and changed tire size on it so I should be correct but haven't checked it.
And I don't know about the mud flaps question.
Ok here are a few more pictures I took today. Hope they help show what you're looking for in the width.
One thing about the BFG's 275/70/18 that I didn't look at before I bought them is the widest wheel they are designed for is the 8.5 inch wheel. I like my stock wheels and all but I've been thinking about upgrading the wheels and now it seems every wheel I like is only made in the 9" size. I have had trouble finding any that I really like in 8.5 size.
I am probably going to put a 6" lift on it later on and run 35's and would like to be able to get some wheels now but 8.5 is the widest for this tire and I'll need the 9's for the 35's I want. If I would have gotten the 285/65/18 I could use the 9" wheel and be able to use them when I get the 6" lift. Just a thought.
YOu didn't get a direct on front pic!
Yeah I forgot to get a good front pic. I took one but it didn't turn out worth a damn and you can't really see anything as far as the tires go.
From the back it looks awesome, I am curious how the front looks. And also a close up pic at the front of the truck looking down one side towards the back of the truck to show how much the tire sticks out the side.
Thanks man this has been a big help!
Give me a few minutes and I'll see what I can come up with. If the sun will cooperate. :(
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
