I'm looking to tint over the factory glaze of the rear window, which as best I can tell is 20% light transmission. My two options are dropping it to 16% or going with 4%. I'd love the look and privacy of the 4%, but obviously it'd be a little easier to see behind me at night with the 16%....
Any opinions? Experience? (I've already checked the local and state laws here, and they're both good to go for the back window)
My recommendation is leaving it alone. The factory dark tint is dark enough. You will run into serious night visibility problems with a very dark tint on the back windows.
I wouldn't go darker than 16% personally; having it at 4% would make your rear view mirror basically useless, kind of like driving a cargo van or something.
On my own truck, I just left the factory tint alone, but I did put 35% tint on the front doors (technically illegal, but I've never been hassled about it on any of my vehicles).
On my 93 a put the darkest tint I could find on my back windows. I loved it. And then one night I backed into the neighbors car. Didn't even see it. But instead of removing the tint I added halogen fog lamps underneath that came on with the backup lights. Those really helped a lot and didn't look half bad since I mounted them way underneath behind the bumper. If you go too dark you may have some visibility issues at night - especially when backing up.
I've been thinking about tinting the front windows to match the others. When you put 35% on the fronts did it match the rest of the windows?
I have double layered limo tint on the back glass and 20% on the sides. No problem.
35% is one shade lighter than the factory tint, but it looks good anyway.
20% would match the factory tint.
The previous owner actually did the tinting, but I measured and the front door windows are 14% and the rear and back windows are 20%. You can't really see any difference from the outside, but you can tell the fronts are slightly darker than the rest from the inside.
WOW! So was that 2 layers of 5% on the back?
Yessir. 2 layers of 3M limo. I've done it to most of my trucks. I like the privacy. The sides are just a bit over legal here at 20% (legal is 35%).
I have limo over factory tint on the daily driver Ford. the fronts are 20% The truck is darker. I like my tint dark.
Living in some of the hottest states I always tinted my truck the darkest you can go. I mean you might as well get a can of black spray paint and go to town on the back three windows,and I like the front sides single limo and I have the front windshield tinted 35% but that's just me. Dont get me wrong if it wasn't for my backup cam I would not hook up my toy box to good.
Limo or Double Limo, then get a backup camera :D
I had my last truck tinted for a bit and loved it but in NH its illegal to tint the drivers or passengers side front windows. After two tint tickets I decided it had to go :(
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,199 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
