gmcsierra93 Posted May 14, 2010 Posted May 14, 2010 I got in my truck (93 GMC Sierra) one night after work and the radio didn't work no lights on it or anything, it is not a stock radio it is a Sony Xplode. Also there was no dome light and the cigarette lighter charger did not work. I checked all the fuses because that seems like it would be the obvious problem. However, all the fuses are good. In my assumption the problem will cure all the things that aren't working. But where do i look next? Thank you for your help.
steriosm Posted May 18, 2010 Posted May 18, 2010 Have you checked your fusable links that run off of the starter? I had a similar problem with an 87 blazer. I got in my truck (93 GMC Sierra) one night after work and the radio didn't work no lights on it or anything, it is not a stock radio it is a Sony Xplode. Also there was no dome light and the cigarette lighter charger did not work. I checked all the fuses because that seems like it would be the obvious problem. However, all the fuses are good. In my assumption the problem will cure all the things that aren't working. But where do i look next? Thank you for your help.
