Tire Pressure Sensors
Right now I have the truck in my sig with stock 20s and they have tire pressure sensors. I've found a 6.2 truck I'm seriously considering purchasing, but it has the Grandpa edition 17" wheels, yack. So, I asked nicely if I could swap my wheels onto the new truck if I get it, and they said "yes". So, the question is, will these tire pressure sensors be picked up by that truck, or are they programmed to each truck specifically?
Muchas Gracias.
they'll work. you just need to follow the relearn procedure in the manual or have the dealer do it.... nothing difficult
As far as the sensors themselves working, they will work. You will probably have to relearn the sensors for the new truck though.
*edit.. just got ninja'd by Matt... lol
lmao!
you need to learn to type faster... lol im on my phone and still snuck that in before ya!
lmao!
Well I have to work with what Uncle Sam provides us, which isn't fast computers and on top of that slow network seeing the whole base is on it.
lmao!
Same here... thats why i use my phone =)
(civilian)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
