How To Remove Rear Headrests
Hi,
I'm trying to make more room for a baby seat.
How do I remove the rear headrest in a new stly extended cab?
Thanks!
There is a tiny hole at the base of the headrest you need to depress. I used a paperclip, then lift and it should come right out.
good luck you need 4 hands. :sick:
I used a small nail to stick in there and press the button and had my wife pull them out.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
