Look At What I Found At Work Today...
terrible1one3
Those are nice trucks. I'd get one if I could afford one. The videos that Ford has on their website are fun to watch.
I looked at those a few months back. Looke cool but it's still a ford :):D
Hideous, overrated, less of a truck than the Silverado in the background, and it looks unfinished with the headlights not fittibng the tack-on fender flares..
There are far better things to spend $45-$50K on....like a Sierra Denali with the 6.2.
+1 lol, this should be in the jokes pages lmao :) (moderator some help please lol)
I don't really like it. :) It seems like EVERY truck website I go to, there it is on the front! It's waay too overexposed already. I'm getting tired of seeing it, frankly. And when you see them in person, driving down the freeway, they just look like a huge rolling cartoon. :D
Definitely underpowered until they get the new 6.2l engine in it.
Not really for me but it is a good looking truck in person. They have three of them parked out front of one of the big dealerships here.
If I lived out in the Southwest US, it might be more appealing. Probably great for light dune/trail riding out there.
It's already out...and costs $3,000...and delivers less HP than the 5.0 V8 and only 43 more torques that equals a rip-off.
Big deal. I can appreciate other vehicles, but this should have been posted on some ford forum IMO.
:) Seriously?? :D You can't compare the Raptor and Denali. That is apples and oranges. Two totally different trucks marketed to totally different demographics.
I saw a Raptor the other day and I thought it looked pretty cool. I'd drive one. :drool:
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 481 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
