I Want To Add A 6 Cd Changer.
Hey folks,
My 2009 Silverado has the radio with the single CD player and I want to add a 6 CD changer. I've seen where plenty have made this swap and had to pay a dealer to re-program the truck so that it will work.....and I've also read where some have had problems where the new radio could NOT be programmed for the truck afterwards!
Have any of y'all seen or heard of anyone taking their original radio apart and replacing JUST the CD drive and swapping the faceplate?
Would this work? I have seen several replacement "repair" drives for sale that simply swap the old drive for a new and that appears to be a very easy task, so I'm thinking that swapping out a single CD drive for a 6 CD drive would be just as easy and taking the 6 CD faceplate and installing it in place of the single CD faceplate would be an easy thing to do as well. In fact, the only difference I can see in the faceplates (buttons/controls) is instead of the button with the 'clock' symbol on it for the standard CD radio, there is the 'load' button on the 6 CD changer and I was even thinking about keeping my old faceplate and just swapping that one button.
Please excuse my ignorance here, 'cause I really don't know, but I would think that this would work? It may even keep me from having to have the truck re-programmed since the bulk of the radio would still be stock?
What y'all think? Is this something worth trying? It seems like a very simple thing, but some of y'all may know whether this will work or not?
I'd only try it if you have access to one of each for cheap or free to play with & test. Otherwise, it may just be a waste of time & money.
Just get a used/new unit all together, have it flashed as need be, and be done with it. You have an interesting point, but regardless, may not be the best idea.
Why not go MP3 or iPod route. You can keep far more tunes at your fingertips. It's the only way for me
My 'test' unit will be my original in my truck now which is one of the main reasons I was hoping at least one of y'all had already came up with this hair brained idea!
:lol:
Now, I will take the replacement apart first, just to be on the safe side and see what's in one.....especially if no one has ever tried this before. I should know fairly quickly just how involved it will turn out to be and won't have hurt anything because my original will still be in the truck at this stage. Seems to me though, the drive is the only difference? The one thing that's making me think that this would work is, I've seen several places that sell "replacement" CD drive units and they ALL say that nothing will need to be done after the replacement of JUST the drive? If that's the case, then the truck doesn't actually know what kind of CD player is installed, just that one is? The one I'm getting as a replacement deck is the exact same type as mine except for the 6 CD changer part. My only thinking was that if I don't change the actual chassis of the unit, I should be able to fool the trucks BCM since there are no other differences in the replacement radios functions or features. I hope?
Now, like you say caddy, it may turn out to be a total waste of time, but it just may work? If it turns out I would need to cut or splice or modify things once I get the radios apart, then absolutely NOT, I won't even try, but if it turns out to be a simple unplug one drive and plug the other in, then it should be worth trying. If all else fails, I would just have to put everything back like it was and go have the replacement programmed, but unless someone chimes in here that has either done this OR knows why it wouldn't work, I plan on AT LEAST seeing what's inside these things and do it just to see what happens.
Ok, I'm interested. What's an MP3 or iPod? Would I have to buy all my CD's over again?
  • 1 month later...
:thumbs:
i tryed taking the face of a single cd and a 6 cd. under the two face plates are totally different and can not be swapped
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
