Oem Bluetooth Option
I have a 2009 GMC Sierra that came new with AM/FM/XM w/Bluetooth (No NAV). I recently bought a NAV unit off ebay and had the dealership to install it. Afterwards, the NAV worked good but I lost the full function of the bluetooth. I can't start a call by pressing the steering wheel control, but I still see my phone sync with the truck and can recieve calls like normal over the trucks speakers. Of course the dealership wants me to buy a NAV unit from them, however they also told me that it may be just a harness issue...
What the heck is wrong with my bluetooth ???
Pretty sure your VCIM module needs to know what radio you have. It still thinks you have you old radio and needs to be re-flashed at the dealer so it knows about your nav radio.
You dealer should have done this ***and*** they should have known this.
Did you buy a VSS/Voice harness with your NAV unit? If you don't have that harness, it can cause issues like this.
Other than that, Royal Vader is 100% correct that your VCIM will need to be re-flashed as well. Tell the dealer to check TIS2WEB/SPS -- there is a different software calibration for the VCIM associated with NAV units than the one associated with non-NAV radios.
I got that harness... I thought it was for the a future backup camera though. But, I will pass as much info as I can get on to the dealership. Thanks...
I'll take all the info I can get... I'm tried of them taking the dash apart changing radios !!!
The radio actually had bluetooth before the NAV install and it worked... so does that mean that the harness was there orginally ??
No.
You will need the VSS/voice harness installed even for the NAV itself to work 100% correctly, first of all. Its purpose is to add the additional wires to the factory harness connectors that would have been there if your truck had come with NAV originally. Because it didn't, the wires in the VSS harness aren't present in your factory harness. Without these wires installed, your NAV will not function properly if it loses GPS signal for some reason (among other things).
Second, you will need to understand that the bluetooth function is NOT a part of the radio, it is a part of OnStar, which is controlled through a separate module called the VCIM. That module -- the OnStar module -- is what needs to be re-programmed in this case (in addition to having the VSS/Voice harness installed). As already stated, GM issues multiple versions of the software for the VCIM, and the correct version of that software is dependent upon which type of radio is installed in your vehicle. Since that part changed, the software for the VCIM must also be changed.
Just curious, what seller did you buy your stuff from? Both of the eBay vendors I've used included a full set of instructions with the NAV systems they sold.
No.
Navs & Wheels
Well so car the dealer noticed that the vcim was not set for Bluetooth. But still no Bluetooth gonna try swithing nav units..
The dealer "noticed"? Did they reprogram the VCIM, or no?
You're not making very much sense at the moment. Questions:
1) What is the part number of the VCIM in your vehicle?
2) What is the part number of the NAV unit you bought and had installed?
I don't know the part numbers for the VCIM... or the NAV. But, what I do know is the VSS Harness was never wired in at all. The first dealership just plugged the end into the radio and tucked the wires in behind things under the dash. So as it stands.... the bluetooth still doesn't work because the dealerships have no idea where to wire it to...
Would someone have a picture of the VSS and where that it is wired to ??
Rusty
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
