Gear Ratio Question
Ok, I've looked and looked and maybe I'm just that stupid, but I can't figure out what my gear ratio on my truck is. It's a 2008 Gmc Sierra ec 5.3 v8 z71
Look in your glove box at the SPID label.
GT4 is 3.73
GT5 is 4.10
GU6 is 3.42
G80 is the locking differential
It's either 3.42 or 3.73, probably 3.73. Look in glove box and there should be a code on the GM parts identification sticker that starts off gt and then a number. Post the g codes and I'll look at them and see what you got.
D*mnit, as soon as I posted, I realized that Rich beat me to it! :thumbs:
GT4...
Would there be any significant difference if I re-geared to 4.10?
I don't know why you'd want to. You'd have to change the rear and front diff. gears. correct speedometer error. less gas mileage on hwy. Better quarter mile times and more torque are all side-effects of lower gears! :thumbs:
Sorry :lol:
What is the code for the 4.56 ratio gears? I know you cannot get those on 1/2 ton pickups, but 1 ton cab and chassis trucks are still available with that gear ratio I think.
I'm going to have to look Pete,I know its not available in anything anymore,even 1-ton chassis-cabs.
I want to say G82, but Rich will back that up when he gets done "looking it up". :thumbs:
Nope,4.56 is RPO code HC4
G82 isn't a good RPO code at all.
I want to say G82, but Rich will back that up when he gets done "looking it up". :lol:
Ok, G82 is an old code for 4.56 gears, It's in my old 71 Cheyenne 1ton truck. Hc4 is more recent. I can't believe I was wrong at something. :thumbs:
Well a lot of the RPO codes like that stay the same year after year,so I can see why you thought G82 was it,Obviously that one changed over the years.
When I looked up the codes for my 2005, 2500HD CC it said:
G80 =Differential, Zexel-torsen, limited-slip, rear
Are all year G80's the Zexel-Torsen mechanical posi units? If so, they are not "lockers" in the usual sense of the term - ie Detroit Locker (Yes/No?)
- - -EDIT
Hummmm... Just looked it up on http://www.compnine.com/
and it states "G80 - Available 1976 to 2009
AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)"
Bummer.... looks like the G80 is in fact, the Eaton aka Detroit Locker style...
Wonder where I found that first RPO look-up site?
- - -EDIT
The RPO "G80" is limited slip in cars. In the trucks it's a mechanical locker. The same RPO codes can mean different things depending on the application.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 209 Guests (See full list)
