Picked Up Some New Toys
mjdxtreme
I picked up some new toys yesterday. I bought 2- 2005 Sea Doo RXT's 215hp. An older man had them and never used them they both have only 13 hours on them. Average speed was like 20mph. Planning to have endless weekends of fun with them.
congrats and thats a really nicely clean garage. i dont think mine will ever look like that. We 5 dirt bikes, 2 quads, 2 sleds, and just a pile of useless shit
Sweet! My brother has one of those and when you put in that unlimited power key, it flies. Just make sure to hold on the the handle bars firmly the first time you do an acceleration test or the ski will leave you in the water behind it. :lol:
I just sold my 2007 RXT's, those are a great looking/riding ski. Only reason I sold mine was to save up for a boat
Congrats, They definitely HAUL ASS!!!
Those absolutely still look new, with so few hours and expired registration from last year, sounds like they've been sitting around unused.
How much did you pick them up for?
I picked everything up for 12k. Both are 2005 RXT's less than 13 hours, the trailer was a 2006 zieman with break set-up. Almost no marks on them what so ever. One has some gel coat cracks where it looks like they bumped the dock but I have been told by a sea doo dealer that I should be able to get it fixed for pretty cheap. I got them registered today and as I was pealing the old stickers off I noticed that they were never used in 2008. I did some researched before and right after I picked them up to make sure I got a great deal and based on my research it puts me at getting them for 3-4k under what they were valued at. I took them out yesterday and they are awsome. They really haul a**. I am glad I made the purchase.
Sweet ski's and sweet deal man. They look brand spanking new...basically are!
Thats a great deal!
I sold mine for $13,500 with 70+ hours on each ski
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 561 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
