Steering Wheel Lock
Hey all,
I just purchased a 2002 Silverado Z71(Automatic) about 5000 miles ago and I'm a little concerned about the steering wheel not locking when the key is out of the ignition.  I thought for sure that all newer vehicles steering wheels locked into position, so the wheel could not be turned when the key is out of the ignition.  I don't know anyone with a 2002 truck and hoped that someone could let me know if this is by design on these new trucks of if this is something I should take to my dealer.  My previous vehicle was a 96 and this trucks steering wheel locked, I just wanted to make sure the new ones still lock before I went into the dealer screaming.  It seems to me if my wheel doesn't lock anyone could just hop in there and start pushing my new baby away.  Any info would be helpful...
Thanks,
Matt
Matt,
The wheel on my 2001 does not lock.  I remember someone else asking about this a while back and it seems GM did away with locking wheels I think with the 2000 model year.  Someone correct me if I'm wrong.
Thanks for the help guys.  I'll have to keep my gun by my bed now in case someone tries to push my truck down the street.  LOL
Thanks again.
Matt
The shifter still locks in park, so they'll have to be pretty strong to roll it away.  And the steering column still locks on trucks with manual transmissions.  Hope you can sleep now.;)
It was posted on here a while back, but I asked my dealer about it and they were going to tear into it, so I stopped them and had them check the new ones!!!! They dont lock!
That's pretty scary a dealer would start ripping things apart.  I'm glad I checked here first before even talking to my dealer.  This is such an awesome place to look for information.  I'm still curious why this feature was removed though.
Yeah, I think the thing GM sent out was posted on here, but I thought I would mention it while I was at the dealer, the next thing I knew, they were asking me if I had enough time to wait while they were going to go into it and see why it wouldnt lock!!!!!!! Thats when I told them to check the other trucks on the lot!!!
I doubt I have ever locked my steering colum in the time that I've had my truck....ever....I figure if they break the door open they know how to bust a locked steering wheel.  :P
Besides I like being able to start my truck with no key in it! heh everyone always says , " Wheres your key!".
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
