Need Advise On Dying Issue Again.
Ok here's the scenario: Had the "truck would just die symptom" three weeks ago, replaced, Fuel pressure regulator, Fuel Filter, Fuel pump. ($500.00 in parts).. Everything ran great for a short 180 mile round trip burn-in.... Then parked it for a day, went to restart, wouldn't start...Same symptom of no fuel being in the fuel line, because after about a minute with key in AUX (And fuel pump running), it started no problem. Then on another test trip, truck stalled again while driving, wouldn't start. Tried cranking for about 30 seconds no go. Waited about three minutes truck started right up...
I suspect the (sit for two days) won't start is lost gas pressure in fuel line (but am not totally sure)... If this is the case, I am guessing that this is also a good guess at what's causing other issue (just dying which it did once). Thoughts? Could the Cruise control module be doing this?
Anyone?
I throw out a guess, do these newer vehicle get vapor lock like the older vehicles did. Maybe this is causing no fuel to run thru??? Or somthing allowing the system not to stay presurized? They are only guesses but I seen no others repond so I would encourage you and give this topic a bump.
While I was in the NAPA store looking into replacing the fuel line cables (the plastic vinyl parts), a fellow told me that he had an issue with a small "trap" as he called it - a dip in the plastic fuel line that he thought caused the fuel pump to work to hard at times, and thus not pump enough fuel. He said once he replaced the vinyl connectors to fuel pump and made sure they were a straight shot, he never had the intermittant dying problem. He too had replaced his fuel pump, filter and pressure regulator.
Had 2000 with same problem.Low pressure from pum.Changed pump then truck wouldn't start. Turned out to be 3 wires shorting together under engine bay fuse panel
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
