yukon25008.1
looking to see some 305/55/20,s mounted if anyone is running them, really would just like to see them before i make a purchase. there gonna be on a 20x9 wheel
I DO I DO. You can check out my garage link in my sig or if you really need I can post pics. I'm just lazy
Matt,
what width is your wheel?
would you mind taking some measurments
height
tread width
sec width
it wouldnt let me see the link, im just looking for the actual height and width of the tire
hey matt.. why do you run only 33psi
Thats just what I started at when i put them on. I run 35 rear and 40 front.
Thought it was best to run 40 all around?
Not as much weight in the back. I run 35 back there to keep the tread wear as even as possible.
yea but what if there an E rated tire (85) psi, wouldnt 35-40 be under inflated and wear wrong?
No, not for a 1500 series truck.
The load carrying capacity of E-rated tires is far beyond what a 1500 truck can handle. Inflating based on max on the tires sidewall will cause an over inflated condition that'll wear the center tread quicker, make the truck ride like a dump truck, and reduce traction due to decreased contact area.
Anything over 40 PSI really is overkill for a non-loaded 1500. I'll bump the rear up to 45-50ish when im towing the boat.
    todd wollemann
    todd wollemann
  • Who's Online   1 Member, 0 Anonymous, 523 Guests (See full list)
