Antenna Connection To Radio
Whats the correct way to remove the ant cable from the back of these new radios. does the cable come out of the black sleeve or does the whole sleeve come out. gmt900. Mine seems stuck and I dont wont to break anything.
it's a locking connector. If it's the one i'm thinking it is you have to pull on the black sleeve instead of the cable. Should come right out then. If it's another connector then there will be a latch on it but i'm guessing just pull back on the black sleeve (while maybe pushing in slighly on the cable).
in my 2009 you just pull.... comes out like every other antenna cable I've pulled. I've removed mine several times b/c of ongoing issues with my PAC ipod adapter.
