2002 Denali Getting To Hot With Ac On
pazzo811
HI I HAVE A 2002 YUKON DENALI I BOUGHT THIS TRUCK IN 05 WITH 55K MILES HAVEN'T DONE ANYTHING TO THIS EXCEPT FOR REGULAR OIL CHANGES AND AND BRAKES AND ROTORS .IAM HAVING A PROMBLEM WITH THE AC IT IS FREEZING COLD WHILE DRIVING BUT KNOW WHEN IAM SITTING IN TRAFFIC OR IDLE THE AC IS NOT AS COLD AND THE TEMPERATURE GAUSE GOES ALMOST TO RED BEFORE I SHUT OFF? ALSO I WOULD LIKE TO DO A TUNE UP WERE SHOULD I START FIRST THANK YOU GUYS?
You need to add coolant/water. Check your thermostat.
You've probably got a coolant leak somewhere. If it never comes out onto the ground, then it could be a head gasket (leaking into the motor).
Does it ever blow white smoke?
check your clutch fan, may need replacing. also check to see if there is any obstructions in the radiator , leafs, dirt, bugs. also when was the coolant changed/flushed. i know my 03 ac will get a little less cold in traffic, or stopped. caused by less air flow at low speed. when GM put E-fans in the 1500 in 05 a lot of the ac issues went away.
hope this helps, good luck
As stated above, check and replace the fan clutch if necessary and/or clean the condenser and radiator fins. What you describe are classic symptoms of low airflow.
TRUCK NEVERBLOWS WHITE SMOKE ALL FLUID ARE PERFECT NO LEAKS NEVER FLUSH OR CHANGED FLUIDS IS THIS SOMETHING I CAN DO MY SELF THANKS
I GOTTA CHECK CLUTCH FAN IS IT SUPPOSE TO RUN ALL THE TIME OR WHEN THE TRUCK REACHES A CERTAIN DEGREE THANKS
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
