Back Up Camera Question
Does anyone know if the rear view mirror from a '10 Equinox is the same mirror from a '10 Silverado? I want to add the rear camera to my truck and have found a good deal on a new takeout if it is the same mirror. I have looked and looked but cannot find a part number for the equinox mirror. I think the Silverado number is 25794381.
