2007 Diesel - Air In Lines
TRUCKII
New owner of a 2007, 2500HD, Duramax. Have put about 1000 miles on it so far. Yesterday did a 400 mile round trip with no hint of a problem. This morning the truck would not start. Tried draining water from the pump - none. Then purged the fuel lines as described in the O/M and it started right up. Question ' is this a normal happening? Should I take it to a dealer for service? The truck has 28,000 miles.
I have an '08 with a few more miles than you. Never had a problem like you describe. With 28k on the ticker though I have to ask, has the fuel filter ever been change?
i have seen some older trucks have lines rubbed through were the lines run under the rear of the cab. and it may not neccesarily leave a puddle, it alow the diesel to drain back to the tank when the truck isn`t running. another possibility is the seal of the fuel filter is not very good. see if it can betightened. :P
