Fuel Guage....ground Straps
I have a wonky fuel guage. It is more than likely the sending unit. I have rebuilt the cluster already.
Now the guage is all over the map. If ai am dribving and slide it into nuetral I get ab accurate reading.
I hear a rumour that it could be a ground or ground strap doing this. Does anyone one know if this is true or possible?
Thanks
The only one that is visable is the one from the filler tube top mount to the frame. Not sure if that makes sense but who knows with grounds
The fuel tank sender actually works on ground. It is a variable resistor (think dimmer switch) on a ground wire. So there are two wires going to the sender, one to ground and one to the gauge. If the connection to ground is no good then yes it will not give correct readings.
It would be nice if it were that simple, but I have a feeling your fuel level sensor inside the sender unit is bad. I was told years ago on here that it's the metal tabs on the sensor that go bad, very prone to malfunctions due to the crappy quality of metal they used. Only fix was to replace the unit which supposedly had upgraded metal on them that lasted longer.
I stand corrected. That sounds like the answer I remember from 6 or 7 years ago on here back when I had my 99. I think though if I remember correctly the sulfur was causing the crappy metal in the fuel sensor thingies to wear out even quicker?
    needafix
    needafix
  • Who's Online   4 Members, 0 Anonymous, 553 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
